I put the bypass on to try to solve this problem but it happens with or without.
The pump is on the slowest speed,its a Wilo 6 metre head, not the best I guess.
The air in the system seems very possible but I can not think where it is as there are only 2 rads which I have bled many times, how much air are we talking about?
The negative pressure in the top of the tank is also a possibility but how could I change that?
I can raise the vent pipes and I have just thought that maybe the F&E tank is too full, this might stop the overflow but it will not stop the suck down when the pump goes on but maybe that is OK?
Maybe I should get the other rads in place so I have a complete system.
Thanks again, if anyone thinks of anything else. I will let you know what happens
Laurie
Laurie
