What's the name of the tool used for making compression rings, in copper pipes?
The tool that I would like the name of, goes inside of the copper pipe and when opened and turned 360 degrees, a ball bearing will form a compression ring in the pipe.
Kingley swaging tool perhaps, used them many moons ago. Page 34 of http://www.theplumbersmerchants.com/pdf/Alexander_Brown_brochure.pdf ?
Each to their own, eh KirkThe tool that I would like the name of, goes inside of the copper pipe and when opened and turned 360 degrees, a ball bearing will form a compression ring in the pipe.
why do you want to know that?
That's it
A bullet is used for swaged compression.
I am doing an assignment on copper pipe connections and jointing.The tool that I would like the name of, goes inside of the copper pipe and when opened and turned 360 degrees, a ball bearing will form a compression ring in the pipe.
But for the life in me can't remember the name of this tool.
Dont forget the nut first !!
