Tool name?
A flaring tool will make special ends on copper pipe - a swaging tool will expand the ends to receive tubing of a similar diameter.
Is this what you mean?
John :)
The tool that I would like the name of, goes inside of the copper pipe and when opened and turned 360 degrees, a ball bearing will form a compression ring in the pipe.
kingley swaging tool they were used a lot in the late 60s.
That's it
So a swaging tool will create a compression ring for non-manipulative joints.
A pipe expander for soldered connections.
A bullet is used for swaged compression.
So swaging tool not for swaged compression connection :confused:
why do you want to know that?
I am doing an assignment on copper pipe connections and jointing.
But for the life in me can't remember the name of this tool.
ok just wondered cause me and Tamz will have then lying buried in our garages in case you wanted one
