sorry lads think i may be a bit mistaken there the towel heater in my other bathroom says 900 watts on it i imagine this one will be the same ,the old blow heater was mounted about 6 foot high can i just lower the connecting box its fused ,or does it need to go outside the bathroomNot if it's 9.5kW you can't.
the furthest i could take it from the bath edge would be 1.5 mtrsWhat is the distance horizontally from the nearest edge of the bath or shower to the proposed new location of the spur?
the one there at the moment seems to be wired through the socket ring main and has no switch but fused.You will be fine at 1.5m away from the bath.
Does the spur have a switch on it?
looks like its fed through the skt ring main cctWhat condition is the cable, is it suitable and safe to use.
Where is this circuit coming form, where is it fed from?
So should not be any overload concerns then.looks like its fed through the skt ring main cctWhat condition is the cable, is it suitable and safe to use.
the ring main skt cct has rcd trip .thanks to all for the helpSo should not be any overload concerns then.looks like its fed through the skt ring main cctWhat condition is the cable, is it suitable and safe to use.
Sound providing you keep within permitted safe zone with route of cable, you should be okay. Remember RCD protection.
