Righty then... after the multimeter testing, the timer is DEFINITELY faulty. Which is also what the Worcester guy said... sooo... I've decided to plump for a new digital thermostat, in the form of the RF701.
Now, this will completely over-ride the timer, and therefore despite it being faulty, I can set it to always on with the switches and the 7 day programmable thermostat will take over.
I'm guessing that the SCR will have to be wired slightly differently (more akin to how it was previously) as the way it was before had the thermostat completely overriding the timer, which is how it should be with a programmable stat, is that right?
Before I order one... will the RF701 be compatible with the current SCR I have?
I'm sure it will be okay, as all it sends is an on and off signal, but wanted to check first.
Also, how will I have to alter the wiring from its current positions?
Many thanks, the trauma is nearly over!
