Y
yaleguy3
The system is set up to activate with any jamming occurring for 30 seconds.
This means anyone jammimg a system in order to enter a property would set off the alarm anyway.
Going on Friedlands 30 second allowance this would mean the alarm would activate at around the same time that most systems have on entry delay anyway.
If you wish to say that shorter lengths of jamming not long enough to set off the alarm may cause a problem then how would that be as the sensors would come back on stream and report. It seems the manufacturers have considered the possible problems and have come up with a viable workaround.
The Friedland system looks for repeated shorter bursts of jamming too with 10 seconds being the trigger point if 3 such events occur within 5 minutes. With any shorter periods of jamming then its not an issue as the sensors will get the ample opportunities to report.
What would be interesting to know is in the monitored systems S21 mentioned how long the jamming occured for or what the parameters are for the pro systems.
