Looking For Roof Vent Tile
11 Jan 2004
Hi guys.
I'm looking for a roof vent tile to suit Marley concrete interlocking tiles.
I know Klober do one, but AFAICS it is 100/125mm diameter. I need 150mm.
Do you know of any manufacturers? An hour on the interwebby has brought up nothing for me.
Thanks.
Do you want a vent, or a roof terminal for a fan?
You should avoid reducing a 150mm fan duct to 100mm if its for a fan
The Ubbink UB41 looks like it may be suitable for ducts up to 160mm
SRE: Thanks. I did briefly consider that, but as woody says, it's for a fan & the flow rate is huge so I don't really want to reduce the diameter.
http://www.tlc-direct.co.uk/Products/SLTD500SILENT.html
580 m3 per hour...
woody: Cheers. What's the difference between a vent and a roof terminal?
I was looking earlier at a Klober Top Vent, which they said you can use as terminal for mechanical ventilation. But it wasn't 150mm.
I'll look at the Ubbink.
They've all got silly names!
If the Ubbink is no good, I'll try the Flopsquirk. :wink:
