BDL said:The boiler is basically a classic chassis and heat exchanger, the pcb is not a 25 board. It was designed to allow British Gas to attach a modem and carry out remote diagnostics via their call centre.
Agile said:I think you need a competent boiler engineer who does not just change parts until it works.
squeeze the red thermistor with a pair of pliers til you hear it crunch a little.
I've got the same issue and whilst waiting for the new thermistor harness to arrive, I thought I'd have nothing to lose trying the above and was pretty shocked to see it seemed to work!
No doubt this is a short term fix and I should replace with a new harness anyway? I've also no idea why this works nor how dangerous it is but several test cycles show the boiler going on and off as usual. In any case, I've got a new harness on order.
