I am in the process of replacing the cord for the 2 way switch. I ended up opening the main switch where the cord ends and is ties into a knot. After replacing the new cord, I am unable to put the switch back together. The switch has small copper edges which make contact while switching on and off which makes the switch work, I have tried to put these in position and screw it back but it does not seem to fit correctly. I hope I have explained the problem.
Could you please kindly advise what the best way to fix it back. Thanks in advance.
