P
peaps2
The answer is no..
You are not qualified and don't even understand the basics of breathable houses. Dry houses are unhealthy and breathable houses balance the humidity at a healthy level...
You are unable to provide ANYTHING to support your insane rants on breathable homes and are giving very bad advice out that will cost a fortune later on down the line...
"Breathability should be central to the design and renovation processes. It affects the health of the building and the occupants, especially as we try to improve the thermal performance of our homes. It also effects the environment, as the materials that provide the best breathability are often the natural, more traditional ones, although only recently have we begun to understand why.
An estimated 75% of building failures are due to water - either rainwater penetration, interstitial condensation or inner surface condensation. This starts with the outside of the building where vapour closed finishes (such as hard cement renders or high resin paints) can cause considerable damage by trapping moisture. It's possible, often desirable, to have a capillary closed external finish but it should usually be vapour open. Research into modern timber frame constructions shows that drying is more effective through vapour open materials than through “vented” cavities, which often have no air movement."
http://www.natural-building.co.uk/art_how_to_prevent_water_damaging _buildings_and _health.htm
