You are missing the point of the question. It is a thought experiment if you like. It is about getting people to think about gravity and whether it has a speed in its influence or whether the removal or adding of a gravitational body effects everything in an instant.
It is not meant to be a realistic situation, just a way of getting people to ponder what is Gravity.
he's only doing what you did in the would you shoot thread uri.![]()
Well what would happen to that gravity if both the sun and earth were to disappear at the same time? If you cannot answer - then I am right. Simples.![]()
Why don't you start a new thread Joe.Well what would happen to that gravity if both the sun and earth were to disappear at the same time? If you cannot answer - then I am right. Simples.![]()
Hey Chappy - I'm waiting for an answer.
How does it?Because the answer to one refutes the answer to the other.
I do not know if your question is realting to my original question Joe? Is it?
If both the Sun and Earth were to go instantly, then my understanding of what ths scientist bods think, there will be ripples from both the areas where the Sun and the Earth were, which would eventually smooth out to nothingness, no gravity pulling either way. To use the rubber sheet example that is popular when discussiong gravity fields, remove the weights and the rubber sheet would bounce up and down until the sheet comes to a standstill.
Does not answer the original question though.
Yes but is it instant?[ Take away the sun and you take away the distortion of space - hence no gravity. Use your noodle - not google.
No.Gedditt yt?
Scientists reckon when the sun has used up most of it's hydrogen, it will expand rapidly to become a red giant, before eventually collapsing to become a white dwarf, then finally a supernova.![]()
