I'm replacing an old CU and have a cable length issue. The incoming circuits to the current board have the live terminals entering the bottom of the old MCBs. Most boards have top entry for supply side, and the lives will not reach (Neutral and earth is no problem) if routing in a bundle to the side of the DIN rail.
I could use crimps inside the CU, but that is something I'd want to avoid if possible. There is no space for a connector strip, or JBs outside the CU, as the wiring comes through the wall only an inch or so from the CU.
My question is: is there any reason why I shouldn't route the lives behind the din-rail, as there is plenty of space to do so (and then they will reach the top of the MCB easily enough), or must they be bunched to one side when using a bottom-entry point on the CU.
