Hi all,
I'm after some advice.
I am converting a US wall light to UK wiring, but as I can't get the correct type of bulb in the UK, I would like to try to add two.
Back of the light in it's current state below:
Diagram below is the current wiring (wire colours not necessarily representative):
As I can't seem to get 5"-6" tubular type bulbs, I am going to try and use 4 x smaller candle bulbs instead, probably 25w.
Can someone suggest the best way to wire this so as each pair of of top and bottom bulbs work as they do singularly - the switch is three/four way - twist once and only the top one comes on, twice and only the bottom comes on, three times and they both come on, four times and they both go off.
Also, becuase of the limited space between the light and the wall, what is the small wire gauge I can use (it will be connected to 1.5mm T&E), and what is the best way to connect this to the T&E - terminal block?
Appreciate any advice.
