combined rain downpipe and soil vent???
22 Oct 2012
Nottinghamshire
hi,
i want to move an exsisting soil vent pipe and rainwater downpipe from inside to an an outside wall. the question is can you install a vent/soil pipe and connect the rainwater pipe to this rather than have to run 2 complete pipes side by side?
currently they both terminate into the same underground pipe 4 inches away from each other?
my concern would be smells and i'd assume to do this you'd need some sort of trap to stop smells coming up the guttering instead.
p.s. i'm talking here about roof line guttering
But isn't the drain at the bottom of the pipe which is currently inside? Where would the drain be on the outside? :|
I'm not sure whether you could boss onto a stack with 63mm rwp.
Even if you could, the air discharge from the resulting rain water outlet would not be high enough should there be any openable windows nearby.
The simplest solution would be to fit a storm gully at the same time as you re-hash the drains for the stack, then drop your rwp into the gully.
Just confirm that it is a combined system once you start digging.
Thanks for the replies,
The drains currently run from a toilet in the back porch under the porch floor to outside then turn 90 degrees to join the other drains from the kitchen, the porch was added years ago and built around the pipes rather than move them.
The rain downpipe drops into a u bend gully which then joins the main soil pipe
No big issue if it can't, just trying to save on the extra 30 quid for pipes gully's and work
