Hi can a socket be fitted in a cupboard of a down stairs shower room to power a tumble dryer if there is a door that can be closed when the tumble dryer is in use? there would be no access to the socket unless you pulled the tumble dryer out.
A lever is a tool.i think the definition is a tool to access or similar so just have a key to lock to comply
You're surely not suggesting that when 'access requiring a tool' is required for safety (e.g. to restrict acces to live conductors) a lever-type door handle would satisfy that requirement? !!A lever is a tool. A door handle is a lever.i think the definition is a tool to access or similar so just have a key to lock to comply
As you know, I can't - but that doesn't make your suggestion any less ridiculous. Maybe even dictionary definitions would be adequate - it is surely quite clear that that the intent is that 'a tool' is something which is 'taken to the job', not a permanent part of the equipment.Can you find me the definition in BS 7671 which contains that provision?
Thanks. A door handle clear does not qualify as (1), but (2) would cover virtually anything (wot's 'an instrument'?) operated 'by hand', potentially including a door handle - although I don't think that something like that would ever be called 'a tool' in everyday usage, do you?tool  noun 1. an implement, especially one held in the hand, as a hammer, saw, or file, for performing or facilitating mechanical operations. 2. any instrument of manual operation.![]()
I'm definitely not forgetting that, since that is my point. I continue to regard it as ridiculous to suggest that a regular door handle (on a door) renders things on the other side of door 'accessible only by use of a tool', don't you? Would you be happy for people to be protected from, say, live busbars by a door equipped with a handle, by means of which anyone could open it? !!Don't forget it is a door.
