And the only way to do that is to flog him a combi ???
Cos that's all you understand !
At the tap, yes. and so does Chris, though he doesn't understand the maths, whereas you don't understand anything.
Well if you will interject like a nobhead, go off at a tangent like a nobhead, look the wrong things up like a nobhead, leave things out like a nobhead, and have to find a pile of verbage about a simple word, like a nobhead, then what do you expect?you think I'm a nobhead
Thanks lads,
My Potterton Kingfisher boiler is now over 30 years old and so reliable so far and I find it hard to go the Combi route
Now have you looked up the efficiency of your Potty King?
And then calculated the cost of the gas you are wasting keeping it?
If your house and gas bill is higher like £1500 pa then you could easily be wasting £400-£500 compared with the cost of running a nice condensing boiler!
Tony
.You have to admit I'm right though, pressure at the tap will be higher in a 22mm pipe
There isn't one, there are many many, depending how approximate you want the answer. But you can't leave relevant things out. If you want to compare plastic and copper there's lots to get right. Plastic isn't as resistive as you'd expect.So what's the equation for pressure drop for water flowing in a pipe?
You have to admit I'm right though, pressure at the tap will be higher in a 22mm pipe.
Never heard so much drivel.![]()
It's been fun.![]()
