Hi all,
Im an electronics engineer by trade but i need some electrical advise regarding regulations ( you boys like complicating things dont you
I have a balcony with a large plant propogator on it. Ideally i need to get power to the propogator (100w max). The only power source reasonably close is the immersion heaters radial circuit! can i use an fcu (original circuit is already rcd protected) to extend the radial circuit out to the balcony with suitable cable?
We never use the immersion heater and even if we did the 100w at 240v is only 410ma so it hardly likely to be any sort of an overload issue even if both were on at once.
Were do i stand with part p? am i ok to do it as its extending an existing circuit or am i not allowed to as its outside?
Lots of thanks in advance
Harry
Harry
