bang!
19 Feb 2013
London
DIY Disaster: Just blew a speed regulator for a small electric motor. It wouldn't work from a DC adapter so I wired it into a mains cable. Silly thing to do but at wits end. Bang! Took out two 13 amp fuses, mercifully didn't blow any of the flat fuses in the main board.
sigh
Back to the drawing board.
PG
You ain't gotcha motor switched on mate :wink:
The motor works great at all voltages on the adapter - couldn't get any sense out of the speed controller though. I'm now stuck with 25 revolutions per second at the lowest setting (3v) but I need 17 revs. I thought adding the speed controller to the circuit would be the perfect answer but it has turned into a DIY nightmare.
A little knowledge can be a dangerous thing, and at times expensive!
Only someone with a death wish would wire somthing requiring low voltage DC, direct to the AC mains.
Wotan
Possibly so, but that would be presuming that they knew something required low voltage DC in the first place. Wisdom after the event is a fine thing indeed ;)
Was there not a clue in the description from the maplin?
It didn't come from Maplin. Anyway, the motor is up & running now and the speed regulator is brilliant. Thanks to all for help, I am older & hopefully a little wiser.
