Is a New Kitchen Socket Notifiable?
3 Aug 2008
A new gas hob came with a plug for the ignition. Previous gas hob was wired directly. If a qualified electrician added a single socket to the end of the already existing wiring, in order to plug in the new hob, is this notifiable or not?
I've read conflicting advice because generally a new socket in a kitchen is notifiable because of the location, but at the same time, it talks about if it also involves new fixed wiring or extending in any way, which this didn't.
Thanks.
If the electrician is registered and can self-certify then what difference does it make?
If you class this as replacing a connector with a socket it would not be notifiable.
Yes.
That applies to replacements which are not notifiable.
After April 6th it all changes and will not be notifiable, so ...
It's not supposed to make sense.
Cut off the plug and wire it the same as now.
Cutting off the plug voids the warranty. The electrician is registered so I took what he said at face value but when you read the official rules it gives you a bit of doubt, and if we come to sell the property and it has a new kitchen, we will get asked for all the proper certs and documents. I just want to make sure it's all legit.
I had assumed (I know I shouldn't) that, as the present hob is wired like this, it was connected to an FCU.
Anyway it is being done by a 'qualified electrician' who will know.
The thread is more about notification than wiring.
Yes, it is not on the list of non-notifiable activities hence adding a socket in a kitchen is notifiable to your local building control.
Wether or not it still is in a few months time is another matter as there are changes afoot.
I am assuming again but I would think that originally ...
either way, theoretically ...
There was a cooker connection unit
which was replaced with a fused connection unit
which is now to be replaced with a socket.
If these things are used to replace what was there before then,
by definition, they are replacements.
Also that oft quoted 'like for like' cannot be found in schedule 4.
replace  
verb (used with object), re·placed, re·plac·ing.
1.
to assume the former role, position, or function of; substitute for (a person or thing): Electricity has replaced gas in lighting.
2.
to provide a substitute or equivalent in the place of: to replace a broken dish.
3.
to restore; return; make good: to replace a sum of money borrowed.
4.
to restore to a former or the proper place: to replace the vase on the table.
