Daft Question - What size hole for 4 x T&E cables?
19 Jan 2006
West Midlands
Before I get a spark to do all the connections, I'm looking to install the T&E to extend a socket ring into our conservatory.
Its a long story but I need to bring 4 x T&E (2.5) the a wall into a accessible box for jointing. Daft question but what size hole/drill bit would I need to adequately fir these 4 cables? I'm guessing 20mm?
Many thanks,
Damian
20mm is just about possible, provided the cables are aligned properly.
25mm would be a far easier choice.
Personally, I would say 20mm is tight for 4 x 2.5mm cables. I would be going 25mm.
Incidently - The largest drill I carry is 25mm. I then go upto core drills from 32mm for larger jobs. Anyone use drill bits larger than 25mm?
See if you can get a borrow of an sds drill and best would be 25mm bit, if you need to be really accurate use a smaller drill first and if necessary you can adjust the drilling of the 25mm hole accordingly.
The smaller hole will act as a pilot, but some adjustment is still possible.
I'm working on the unknown theory that the wall is brick, brick render or block
I have a 28mm bit for passing 25mm conduit through walls
No unless you like seeing customers faces when you blow great bg bits of brick away
Another reason for doing a pass with a sub 10 mm bit first, then you use the bad boy and go 75% one way and 25% the other. Some walls, well even the most gentle push and it looks like C4 was used :wink:
