Maplins sell them for about £13 poundsserial cable (20quid)
If it is a simple serial cable then buy 9 way D connectors from Maplins and make your own. http://www.maplin.co.uk/d-sub-connectors-1113[/QUOTE]
£13 sounds good...although Maplin are usually far more expensive for many items. Not quite sure what exactly the cable is made up of, but I'll take a look this evening.
Many thanks.
The cable has a small circuit board in the middle of it which converts the TTL signal level of the panel to RS232 or USB signal levels, its nothing like a normal serial cable.
That white contact on a nice hardwood door looks horrible. I'd probably go with a brown flush mounted contact as its essentially an internal door.
Yes, those flush contacts have the same 5 terminals in a circle. Even more fun getting the resistors in. You can get them with built in resistors but I don't know of a supplier for DIY.I'll look into the flush versions - these:
http://www.alertelectrical.com/prod/1224/flush-mounting-burglar-alarm-contact-brown
And by the looks of them, they seem to be the same, wiring wise (5 screws in a circular format rather than straight)?
I'll have a look at the front door to see how I can neatly wire them, but as mentioned above, I can drill in at an angle near the top for the cable (might have to paint the cable however!).
I'm struggling to find those 'Premier Elite USB-Com - USB Interface Connectors' for less than £30 though...
They both do the same job....is there any real world difference between the functionality of the serial and USB cables? one of my many old laptops will have a serial port...
One or two 12V 7Ah batteries or one 12V 17Ah battery can be fitted inside the control panel (metal housing) to provide continued operation in the event of an AC mains failure.
Yes it is likely to get noisy when you start it up, probably best to leave the external sounder disconnected and loop its tamper, this will let you play with the programming and test most of the system without aggravating the neighbours. Connect the external sounder once you are happy with everything else.Stoopid question, but when i power up the alarm properly for the first time, I presume the sounders will not just start going off if somethings not set right??
Or is it normal practive to unwire these, loop the tampers and only connect these once it looks right?
Is there an 'engineer mode' to be able to create alarms (for the dialers etc) but without having the bells go off, or do they just have to be unwired?
If the bell gets wired in, how does one unwire it without triggering the alarm? is there a software 'turn bell off' type setting?
Sorry for questions, but will be turning it on in the next couple of days and want to stay neigher friendly![]()
