You need to use the flex in A &B.
Add Live and neutral in L and N.
If this doesnt work, you've probably knackered the relay in the BDR by putting a short across it. Incidentally, the dividing partition between the mains volts and volt free contacts is not intended to crush the cabling. Either mount the BDR on a pattress box or cut out the partition, if it is 230v you are switching.
Simon
hon eywell HIN installer
can you please show a picture of a sketch please?
thanks
