My view is that there is some kind of intermittent fault in your boiler!
They are so stable that they can be operated with no flow at all and just sit there keeping themselves hot by firing up for a few minutes every 15 min or so.
Converting to a fully pumped system would be much more efficient, give faster HW heatup and save gas costs. But not solve your problem
You did add heat transfer paste to the temp sensor point didn't you?
Tony
Hi Tony,
No, i didn't but asked the plumber to do it when he serviced the boiler but had a look earlier and it's the same as I left it. I've just nipped down to Plumb Centre and got a tube but when I unclipped the thermistor the two wires with the 'bulb' at the end were 'squashed' around the body of the thermistor. There is a hole in the 'socket' where the thermistor sits; should the wires and bulb be pushed through or is it ok to 'coil' the the two wires connected to the 'bulb' into the socket?
What exactly does a thermistor do and how much (and where) should the thermal paste be applied?
It's all a little academic at the moment as one of the wires connecting to the buld has come off so I need to order a replacement thermistor anyway but will need to know when I fit the new one.
thanks again,
Steve
