But you have to supply every single wiring point and accessory with a CPC. How are you going to acheive this if you've over-sleeved the green and yellow wire to use it for something else?
Assuming you're registered with some body why not ask them, or do you just pay your money because you have too then take no notice of what they say.
Go on be a devil.
"Question, I'm wiring a room stat in a custards house, is it acceptable to over-sleeve the green and yellow as the switch wire"
No need, its in BS7671
411.3.1.1
A circuit protective conductor shall be run to and terminated at each point in wiring and at each accessory except a lampholder having no exposed-conductive-parts and suspended from such a point.
Even if they did say different, im gonna go with the IET every day of the week
Can't believe I got suckered into this discussion again.
They say it's acceptable to over-sleeve the green and yellow for use as a switch live in control wiring.
What was the specific question you asked the IET?
It is acceptable - but then you've got to find a way of running a CPC. You never ask them whether it's OK to not run a CPC, do you?They say it's acceptable to over-sleeve the green and yellow for use as a switch live in control wiring.
