Hi, just wonder if someone can help..
I would like to instal inset wood burner in to chimney breast hole.
try to achieved something like this:
and this is the inset wood burner which I plan to fit:
From seller info:
Front of fire: 692mm wide, 520mm high, depth(from front of stove) 380mm.
The hole in the wall needs to be: 620mm wide, 500mm high and at least 350mm deep
This gives me 20mm difference between fire and the hole (vertical) , so looks like 10mm top and 10mm bottom frame ( if I'm right), just don't know how to connect flue pipe when this goes in to the hole with no space around, how to slide flue on top of burner, how to secure, how to seal it, can I do it from inside wood burner ? Can I finish front of the chimney without having inset just leave the hole and flue pipe with reg. plate and fit it later, or fit the inset burner first then build the bricks around it. ?
How this things get installed ?
From seller info:
