It's naive to put your blinkers on for just one brand, there's lots of kit out there which is sold as the best thing since sliced bread.
I'm rather good at fixing these awesome boilers, wouldn't it be great if they could make a appliance that just worked, but then that wouldn't be much fun would it? And I'd be out of a job![]()
For the aid of the Googleer though he should direct his searching towards low loss headers.
A large ATAG does not require low loss headers as standard. You knowledge of heating system is scant.
No, an idiot costs up the cheapest method.An intelligent man will assess properly, cost up as use the cheapest and easiest route meeting the customers needs.
Which is irrelevant to a large combi vs a system boiler/external controls/unvented cylinder. A wandering mind.
Keep the insults coming, I love it. Insults are when you have lost. And boy you lots are big losers.
On compromise, in an ideal world, a combi (for example) would heat up from cold and provide DHW the instant a hot tap is turned on. It would provide DHW of adequate temperature at whatever flow rate the customer wanted. And it would range down to arbitrarily low outputs (perhaps only a few hundred watts), at arbitrarily low flow rates, so as to be able to match the requirements for the CH system. And for good measure, it would be 100% reliable.
In the real world, such a combi doesn't exist - so we have to make compromises.
Wrong. A single zone does not need a header. All this is trivial and beside the point of The point of a large output quality combi vs. a system boiler/external controls/unvented cylinder. The combi wins hands down.A large ATAG does not require low loss headers as standard. You knowledge of heating system is scant.
yes it does. regards, atag service agent.
