you dont need to drill the full 50mm likely to be a 38mm plug so 43 max
can you not go for another brick or the cement lines
You're right. The plug is much shorter about 38mm. Would the cement be much easier? Its unlikely I could match up the four holes to cement, I could of course get two done that way.
