I found using an IR thermometer was easier/quicker ... because of the varying emissivity of the surfaces you might aim it at ...putting a standard target of a bit of black insulation tape where I was going to measure improved the accuracy of the measurement I think.
You also have to take into account that an IR averages over an area, which varies with distance from IR to target - think of a torch beam. You get best results when the IR is in contact with the pipe.
Ok tonight I have had to alter a couple of radiators ever so slightly were talking of 1/16 -1/8th of a turn as with the lower flow temp the radiators were cool along the bottom.
Yes all seems to be ok now. Even running at the lower temps the burner runs for about 4/5 mins once its cycling whereas before it was more like 30seconds
