Move light switch upwards - any advice please.
Status
Not open for further replies.
17 Feb 2010
Yorkshire
I am installing 'Easipanel' panelling in my hallway.
I have successfully fitted it around electrical points etc. so far.
My current problem is that at one end of the hallway a light switch is high enough to easily clear the panelling and dado rail.
But, for some reason, near the living room door the light switch is a reasonable amount lower. I have attached a picture that shows the switch. The dado has not been installed on this section but is about 50mm in height.
I could cut into the dado to clear the light switch. But, I'd like to move the light switch upwards.
I would like to know if its possible to tell here if it would still be in the 'safe zone' if I did this. I assume there is going to be enough cable slack if the cable comes from above?
My plastering skills are limited. I do have basic tools (plaster board knife/saw etc) and i have built a 'fake' chimney breast before (dry lined) but this didn't involve patching an area like this. Would the best approach be to try and cut the back box out, mark up the new position and then saw upwards?
How would it be best to patch up the remaining cut out area once the back box is moved?
[/img]
You say "saw upwards."
Do you know it is plasterboard?
Is it dry-lined or dot and dab?
Cable will still be running to a visible accessory so permitted zone is not an issue PROVIDED there are no horizontal cables.
Cut out the new box hole very carefully in case you slice through the buried cable.
Polyfiller will fill the hole.
I am installing 'Easipanel' panelling in my hallway .... i have built a 'fake' chimney breast before
One of the regulars will be along soon to tell you how horribly dangerous those things stuffed into the sockets are, how you'd be better off without them and how they should be banned.
I guess you don't need to make good extra-neatly, as the gap will be covered by dado.
Will you raise the box just enough so the bottom of the switch plate is resting on the dado?
You could put a small length of timber in the hole a screw it in place either side, screwing the waste plasterboard you remove from the new switch position in the hole.
Oh, hang on, scrap that! The dado is only 50mm. You only want to move it up a smidges.... :wink:
I think you need to read my question. Nowhere was I soliciting for advice in what I had plugged into the electrical sockets.
Not sure what the puzzled face is for....keyboard warrior at work here obviously.
Sounds like a good idea; I will be moving it up a little more as I want to clear the dado by at least 20mm or so.
I think you need to realise that people are free to give you whatever advice they think you need, especially if they believe you are putting people's lives at risk.
It was just an observation.
My wife puts them in the sockets. We have small children. Their presence means the children are now disinterested in the sockets, whereas previously they found them fascinating. No children have so far died. I am well away of the fact that they can be removed and inserted the wrong way up, this opening the live and neutral pin sockets. I am also aware of the fact the existing socket has built in protection against this. I have also explained this to my wife. Thank you for your concern. I feel touched.
I don't think the puzzled face qualifies as an observation. Exactly what are you conveying?
That's an interesting reaction from your children. My daughter had the opposite response from her children, which I put down to her paying less attention to the children playing with a 'non-electrical' thing plugged into the socket than she did to them trying to play with a 13A plug.
Please be aware that as well as the risk you mention, these devices often damage the socket-outlets they are plugged into, leading to overheating.
That's the way it is with risks.
So you are aware that they can make things worse. Are you aware that they can damage sockets?
http://search.diynot.com/forum_sear...hor=FatallyFlawed&search=Search+Forum&stype=0
Maybe you are.
I do.
The name of the smiley might be "Confused", and the code for it might be
:?, but to me it looks like a wry smile.
Maybe you are.
I do.
A wry smile? Maybe they should do a 'condescending with an overall feeling of superiority' emoticon for you...
Status
