guys,
I know this may be daft for most but I was wondering, with any male parallel how do you go about sealing to female parallel correctly? Should a washer/o-ring/fibre be at the bottom of the threads or at the top under the hex bit??
and can somebody share a link as to what the actual item used is to seal?
I was also wondering is there a real need anywhere to use male parallel fittings? Can somebody please advise when it would be used over a taper? I know female parallel exist but so far I aint had to deal with one.
thanks
thanks
