Hi first post here,
I have a procombi ct25 boiler which has just started to fail on me. The last day it started to make a noise akin to constant boiling water. This is not the usual noise leading me to suspect that a component has failed or air has somehow got into the system. I tried bleeding the heat exchanger on top of the boiler with no joy and also tried to bleed the tallest radiator with no success.
Does anyone have any clues on a potential solution regarding length of time to bleed, whether the boiler should be on doing it to force the air through or whether there is a genuine part fault.
Cheers in advance
Cheers in advance
