Drilled into electric cable
But if there's an accessory (or Consumer Unit) underneath the cable run, the safe zone extends down to the accessory and extends to the width of it.
This is why I suggested he reads up on safe zones, since where he drilled is likely to be in 3 of them! 150 from a corner, 150 from a ceiling and directly above the CU (an assumption which is why I asked for a photo from further back)
I bet that was the Stanley knife used to cut away the plaster.
Another very near miss.
My goodness, you are probably right and that is even more terrifying than the drilled hole. The person who cut that is very lucky to be alive and not to have some very nasty burns.
Whilst the cables appear to be in a safe zone (a wider photo would be good to determine that), would you ever run a concealed cable before a domestic CU without setting it at least 50mm back or mechanically protecting it? Just a general question for the domestic electricians on here. As mentioned most people do not understand safe zones, or even give any thought to how switches and sockets get their power. The number of shelves on living room walls around the country with brackets directly above sockets or in the corners of rooms, and pretty much any DIY kitchen with wall units is testament to that.
Its interesting.
I was trying to work out where my tails go last week.
CU in a garage thats now been converted to a room (and not very well).
Looks like my tails go up 10 inches (26cm) to the side of the CU.
Not sure how they get from there, to the other side of the closet where the meter is. Would they be in the roof space? or around a door frame?
A severe electric shock requires two points of contact with the body to enable significant current to flow through the person. So unless they were touching something earthed or neutral when they cut into the cable they would only get a mild "shock" ( a tingle ) due to capacitive coupling of body to earth.
Do NOT try that as a damp wall can provide an earth sufficient to allow muscle jerking current to flow Most electrical accidents are due to muscle jerks causing people to fall off ladders.
All the cables here run above a door from the consumer unit. Of course the same thing happened here, not by me, but he managed to short out live and earth and it blew the main 100amp fuse. DNO were not too impressed.
You can never rely on save zones, always use a detector if you are not sure.
I don't understand how this person didn't get a massive shock, I can only assume it was because the blade of the knife some how only touched the insulation and not the copper.
That looks like your main tails to the consumer unit. Is it or the meter under where you are drilling. You have been very lucky!
Due to the nature of the cable and it's damage I'm afraid you need an electrician asap. Please keep away from the cable as it is LIVE !!
Yeah it is quite near the consumer unit. Doh!
MachineMart are a much better source of low-cost arc-welders...
The severity of a shock off the mains depends mainly on the current path through the body and how good the return path is. If there is no return path then at least in theory you shouldn't get a serious shock*. The current rating of the circuit is pretty much irrelevent**.
* In practice I wouldn't want to rely on it outside of VERY carefully controlled conditions. The risk of their being a return path you didn't account for is too high.
** Yes a lighting circuit is likely to have a higher source impedance than the meter tails but it will still most likely be < 1 ohm which is negligable compared to the resistance of the body.
