Hey Guys.
I have 3 Storage heaters in my property.
2 x Creda 79162
1 x Creda 79152.
A few month ago i noticed a burning smell in the kitchen, then realised it was the RCD for the E7. One of the fuses had burnt, and taken the two adjacent fuses out even though the other two connnected Storage Heaters worked fine.
I Call the local Leccy, he replaced the fuses and checked the wiring.
The RCD
A few days ago one of the storage heaters stopped working, so i opened it up and noticed there was a lump of metal that had melted.
I have also noticed that the heaters never seem to cool down, even by the time evening comes. I checked the meter reading and these are quite high.
I called nPower and they said the meter serial number i provided was for a normal meter not an E7 and that they thought i was on a normal meter tariff.
This leads me to think the Storage heaters are never going off.
What controls the Timing of the E7, the Meter or a seperate timer?
This is the meter:
Back to the thermal link....
I think this is a thermal Link.
Anyways i called around to find a supplier no one seems to stock them locally, however a local electrical factor said to use something called a Micro temp. He said the Thermal links are designed to melt at a certain temp, where as the micro temps are designed to fuse.
He also said the thermal link i need is 179C but the micro temp is 184C.
Is it safe for me to use this?
2 x Creda 79162
1 x Creda 79152.
The RCD
This is the meter:
