Sorry don't know, has a logo of black disc with red triangle pointing out of it.What brand of CU is it?
Control Gear Direct then?
Would like to know the model though. If it is not an S type then I would expect it to trip as any earth leak over 100mA will set it off.Yes that's it, CU made by Control Gear Direct, thanks TTC.
Sorry, I got my facts a bit muddled.Would like to know the model though. If it is not an S type then I would expect it to trip as any earth leak over 100mA will set it off.
I've never seen an S type RCBO. A PHOTO might be interesting.
The offending RCD was a 100A 100mA time delayed RCCB (not an RCBO) from Control Gear Direct.What make and model is the offending RCBO?
It does have a small square with an "S" in it next to another with a "~", guessing that 6027 11 is the part number. Is Legrand one of the better makes?Looking at your photo of the LeGrand, I don't see any labelling to indicate that it is time-delayed (S-type). Can you see a part number?
OK, here is a picture of what is in the meter box.There also doesn't appear to be any over current protection between the meter & the SWA ..... which there should be!
And the SWA doesn't appear to be terminated using a proper gland. Please show us a pic of the cutout/meter/RCD/swa taken from a little further back.
the resistance provided by our domestic earth rod
