Hi guys please help
is a straight cut 1/4" shaft the same as a 1/2" worktop cutting bit?
As the routher i have is only a 1/4" 3/8"
So cant use a 1/2" worktop cutting bit!!!!!!!
im planning to get a trend unibase to fit to it so i can use a 30mm bush.
With 900mm worktop jig for mason miters.
I can only find 1/2" worktop cutting bits but they look the same as a straight twin flute bit???
want to use a 1/4" TCT 16mm + 20mm straight cutter with a 30mm bush on a jig can it be done this way???
