Clearance regulations for built in gas hobs
10 Jun 2014
Birmingham
Hi, have just moved in to a new build house and they have fitted an AEG gas hob (built into the work top). What is the minimum clearance or gap that should be between the hob and the back wall or splash back?
tom you are better off asking in the plumbing section but i suspect the answer is in the manufacturers instruction manual,which you should have in your home pack
