Please help someone
I recently moved into an apartment and one of the dimmer switches wasn't working. So I bought a replacement, but when I went to replace it I found 3 red wires (unlike any videos or tutorials I have found).
So I copied the set up of the previous (broken) switch and put the one red wire in the C and the other two reds in L1 and L2, but it didn't work properly, and stopped other lights working.
So I started switching the three reds around in the C, L1, L2 trying different combinations. None worked properly, and now I don't know which wire is which. I have tried all possible combinations and none work. What's worse is that each combination stops other lights working. So now I have all lights turned off and I'm stuck. Any advice would be really really welcome. Thank you.
