- Joined
- 21 Jul 2007
- Messages
- 237
- Reaction score
- 5
- Country
Well we all know it went south, but where can I get a new nut from?
I suspect its M2?
I suspect its M2?
if you mean a nut on the end of your float arm, there isn't one. There is a threaded socket in the float.
Perhaps you should start thinking about saving up for a new valve.
The noise is due the washer in the fill valve vibrating......it needs renewing if you are able to dismantle the valve.
As an alternative, fit a new fill valve.
John![]()
ooooooh, the expense!
http://www.screwfix.com/search?search=ballcock[/QUOTE]
Me just need the nut for now, once its "rented" then the business can pay for the damn thing to be replaced. Probably tie it in with the boiler check.![]()
