One would certainly hope so, but ....Looking at the pics, I am still sure they are not rubber, but will ask the electrician to verify. Will young sparky's (25 years old) no about such old things???
That's good to hear - and roughly what we were expecting/hoping.Had a full survey done yesterday. ... Sockets and bonding are fine. Lighting does need a rewire as no earth (as suspected) and some of the upstairs lighting is in a state due to previous owners bad DIY. ... Getting a quote later but should be some way less than the £7200 quoted by the first sparky.
Do you mean "sockets"? Per the above, it doesn't sound as if any re-wiring of the sockets will be necessary - or am I misunderstanding?The sockets look to have conduits so hopefully get away with a bit of chasing through the ceilings and no damage to the floor
Thanks for clarifying - that makes more sense!Sorry, meant light switches seem to have conduits so the electrician was hopeful that he wouldn't have to damage the walls.
One doesn't normally 'chase' ceilings (usually couldn't) - I suspect you are just talking about damage to ceilings.The 2 areas of ceiling that will need chasing are both in need of a replaster anyway so not overly bothered about them.
Indeed, and that will presumably involve making some holes in the ceilings to gain access to that wiring - but that's not the same as 'chasing' (which is cutting a channel into a wall or floor in which to put a cable).He said it was possible to reach the wiring for the ground floor ceiling lights via the ceiling instead of ripping up the floor on the 1st floor landing
You're welcome. We all learn from our mistakes but, as you imply, with things like electricity one needs to try to ensure that one doesn't make any serious ones!Ah that sounds good, so maybe not as destructive as first feared. ... Thank you for all your advice on this John. Always difficult when you know nothing about a subject and electricity is not one where you can learn from your mistakes
