Missing cover from switch fuse
22 Jan 2012
UK
I got hold of a switch fuse when my brothers heating system was replaced, but unfortunately the electrician doing the work chucked the part that protects the area around the switch.
Anyone know where a spare can be obtained, or can one be made up with a bit of plastic?
Thanks!
As a matter of interest ... even if there's meant to be a protective cover, why on earth is the hole in the casing so much larger than what would be required for the switch, thereby exposing what are presumably live bits of brass? Is it perhaps a 'multi-purpose' casing?
It's so you can only see the 'off' or 'on' as it slides up and down.
If the missing bit is plastic, as it appears on the TLC website, presumably it's to achieve the necessary clearance from the live parts to the enclosure.
Yes, but the same could be achieved with a hole in the case the same size as that in the 'insert' we're talking about - after all, that's how the good-old Wylex Standard CUs did it with essentially the same sort of switch arrangement, isn't it?
Unless, as I suggested, the case is 'multi-purpose', I see no reason why that 'insert' is needed - the same size hole could just as easily be in case itself (which would be cheaper - so I guess there must be some reason!).
Yes, I suppose that's a possibility - but, if that's necessary, the equivalent could presumably be incorporated into the switch, thereby making for a simpler/cheaper case?
The equivalent what? The switch is probably a standard component used in a number of assemblies, not all of which use a metal enclosure.
I was only asking out of interest :-) As for your question, would not just a bit of suitably shaped plastic which could be slipped over the front of the switch achieve the desired separation of switch and casing?
No, the clearance is a distance. Are you getting confused with creepage?
I don't really understand. The plastic component I was postulating would have thickness, thereby creating a distance. Anyway, my inquisitiveness is probably now satisfied, and I'll just accept that they decided it was best to do it as they did!
Thanks all,
I can find 1 or 2 for £15, but the majority are £50+
I just don't want to chuck the whole thing away, seems so wasteful.
I'll have a go I think at cutting a piece of 2 or 3mm plastic and gluing it to the inside, copying what the original would have looked like.
This may be what you want - dimensions (mm) shown are the raised piece, which should be the size of the hole in the switchfuse cover
Have several of these so can post one to you if it's the right size.
That is very generous of you! I have measured, and yes its the correct size.
Not sure if there is a way on this forum to send you a private message as I don't especially wish to publish my email address on the open forum.
I will be happy to pay you P+P for this :)
Cheers
Tim
