Ok so just moved in our house today and notice this:
40mcb in main cu to 10mm twin and Earth then it leads to a double pole 100amp isolator switch (in seperate housing about 1m away ) the next to that there is a metal box what the 6mm cable in from the shed. In the metal box the swa cable creates a earthing point as they used the armor as Earth ( the live and neutral go straight to the 100amp isolator switch) and the earth goes straight to the main cu ....
The cable is protected by the 40a mcb and i think there used the 100a as a main switch to cut both neutral and live off.. It work like a treat but does it sound correct in general
