Soft start dimmer
31 Mar 2006
Leeds
Hello all. Having a bit of a problem. I have a customer with 4no. twin arm wall lights with 60W SES golf ball lamps in each lampholder. Every time a lamp fails it's taking the dimmer out too for some reason. It's happened twice in three days now. The last dimmer was a 600W Hamilton dimmer.
Obviously this is not a good situation. I was thinking a soft start dimmer should help reduce or stop this happening in future but I can't find one rated high enough.
It needs to fit a 1 gang 25mm flush box and be in polished chrome or be a standard dimmer module to fit the existing plate.
Does such a thing exist? I've looked for a dimmable LED of the same size and brightness to reduce the load but also drawing a blank on this.
Any help much appreciated.
Hi I would advise the customer to go the led route, I would think after a few replacement dimmers, that won't be difficult !
Regards,
DS
I was thinking a soft start dimmer should help reduce or stop this happening in future ....
Do you have experience of that approach working? I ask because it sounds rather like 'wishful thinking' to me - even the 'slow start' presumably assumes that the load is of a 'reasonable' impedance. If it falls to near-zero as a lamp fails, potentially considerable (perhaps 'damaging') currents are still likely to flow, transiently, aren't they?
I have to say, that I have found the MK 'intelligent ' dimmers are very reliable and are resilient to lamps blowing and short duration overloads and bounce back with no problems. However, I don't think they make a 600W PC finish which is what RF requires.
Regards,
DS
