Hi All
I have always found it hit and miss with drill bit size and the Blue tapcon screws when fixing back box's......
I don't want to drill small pilot (which will go through box holes/4mm), remove metal clad, then drill a 6mm hole, the fit a plug, then fix the socket with standard screw.....
I just want to drill through the box with a mason bit that will fit the hole size in the box's, then go straight in with a Tapcon/self cutting screw.
What do you sparkies use ?
I will be going into brick mainly BUT some places are dense concrete block.
Cheers
Cheers
