I had some woes last night when my washing machine decided to blow a fuse last night mid cycle. It is currently fed via a fused spur above the kitchen work surfaces, the spur then feeds a single switched socket outlet under the work surfaces behind the washing machine. The fuse in the plug was the one that blew so had to drag the machine out. Is there any real reason I couldn't replace the under counter outlet with a 15A socket outlet ( Round pins) and put a 15 A plug on the washing machine? It would remove the in inexcessible fuse and retain the unplug ability of the Washing machine. Any ideas?
