Making a mini-workshop out of a garage
18 Aug 2008
Devon
I have a garage in an estate and it would be nice if I could use a few power tools in there without having to use a power supply.
I'd like to think in this day and age with all the technological advancements there's a way of being able to run some low consumtion tools like a mini-band saw or chopsaw for perhaps an hour (continuous use).
The estate management prohibit mains electric in the garages but there's nothing in the lease about the use of batteries for e.g. lighting etc.
I have a small three phase generator (the £100 ones) which works perfectly well but is noisy and will disturb people nearby.
I welcome any suggestions for a possible workaround. In terms of budget I have a few hundred to spend on a solution
Cheapest option will probably be a car battery and an inverter. You could put the battery on a small trolley to drag it to the house for charging. You'll need a fairly good inverter to run power tools.
Have you heard about leisure batteries? I've read that normal car batteries don't function well from prolonged use because they are designed to provide a surge of electricity to start a vehicle and not consistent power output.
What BA said above sounds sensible. Battery lights of some sort. You can get "quiet" generators which might solve the problem for occasional use of bigger kit.
If it's a lock up though, you'll need to think about security. Who will know what's in there, and how easy is it to get into?
Food for thought.
At present I have a cordless dewalt drill which will be useful for pocket hole joints (I have the jig already).
I have a chop saw which runs off a normal 240v but it's a naff one anyway, I could perhaps go for that battery powered ryobi, and again that cordless router you linked is good value as well.
I'd like a mini-table saw for stripping lengths, but I can't see much in the way of cordless, any suggestion ?
I'd like a bandsaw for lazy man's dovetail joints, but not much in the way of cordless either, any suggestion ?
Yes I know ''use a saw'', however I'd like as neat and easy job as possible ;)
How about this ? http://www.maplin.co.uk/p/rechargeable-10w-led-work-light-a92rw
http://www.leoindustries.com/light_level_recommendations.php
It would save having to buy a battery to run the lights off.
Can't say I'm keen on leds, two halogens I'd prefer. Ideally I'd like over 1000 lumens for the work space, so two of these suspended from the ceiling might work, I hate the spectrum though. Two would be £80 away, perhaps there is a cheaper alternative.
So far then, given the above tools as a potential I'm looking at around £400-500 setup.
Your question about security; well nothing of value is kept in the garage. I don't leave tools in there. Also I'm having the door replaced in a week or two as the existing one is buggered !
You have progressed quickly :)
Saturday -
Bit of scrap ply and knock up as rough as looking one as possible , add a few tasteless stickers and paint splashes ,job done . Much less pinch able than a nice shiney named box.
Wouldn't know where to start in making one ... ?
Hi, sadly I can't use intuition in the workshop, even for something you might deem straightforward such as a tool box. The way the box clips together, the sorts of hinges and their replacement, the overall specification I'd need to copy from someone whose done it and made a success of it. I'm the sort of person that needs to see the start to completion, it's not easy for me.
Make a drawing then. Nobody starts out knowing what "works" by instinct. If you think about a case, it really is just a wooden box cut into two pieces to make the case and the lid. Hinges are usually what's on the shelf that fits. Couple of over centre catches and a handle. Foam or wooden blocks inside to locate the tool. Incidentally power tools are very nice, but you don't "have to have them" if what you're doing is just for yourself. Up until fairly recent times an awful lot of work was done with handtools.
That's a nice bench, it doesn't look as though there's anything like this battery powered though.
The stand alone cordless table and band saws don't seem that popular either. Hmmm.
your tools clamp onto the the base its no more than a housing for your tools mains or battery
Oh I see now, not bad at all.
I've got lights coming in the next few days. 2 x 20w LED work lamps, 6 hours running time each, so I'm a little further along
