I need to replace a very old lighting system in my cellar. Part of the problem is the cellar is damp and part of it passes outside the house so water actually drips through the ceiling when it rains.
I have envisaged a series of IP65 bulkhead lights mounted in the ceiling (the cellar is 100ft long) connected with conduit but now I'm thinking it's not so straightforward. I have had a number of thoughts...
If I connect the conduit directly to the luminaries (one in then one out the other side) with male adapters then am I making a future problem for myself if I ever need to change the light fitting as it will be difficult to extract the fitting from the installed conduit system? Or should I terminate the conduit before each light fitting to a gland then run cable a few inches to a gland in the the light fitting and then the same in reverse on the other side of the light fitting?
If I go the adapter route and connect everything directly together, how do I make the connections to the light fitting as waterproof as possible? IP65 luminaries are easy enough to come by but how waterproof are the adapters to connect the conduit? Is silicone grease or similar going to be enough?
Any thoughts gratefully received.
