Hi All,
Reading through some online installation instructions for shower waste pumps they dob't specifically state what x section cable to use. If given the following information for example, what would be the minimum sq mm? Thanks.
'230V AC power supply must be provided with a two-pole isolator switch and a dedicated circuit with a 30mA RCD device installed in accordance with the latest revision of the IEE wiring regulations BS7671. It must be wired into a fused, unswitched, fixed wiring connector fitted with a 5amp fuse'
