Source for 8mm Brown, Blue and Green/Yellow Sleeving
9 Nov 2013
Aberdeenshire
I must be looking in the wrong places, but I can't find a source for Brown, Blue and Gn/Ye sleeving in a size suitable for 10mm insulated cable. The insulation is just over 6mm outside diameter, and it appears that sleeving is sized on O/D, so 6mm sleeving won't fit. I only need a couple of feet of each, so don't want 100m reels. Would prefer not to use heat shrink (which I can't find in Gn/Ye in any case). Really don't want to have to resort to wrapping in PVC tape of the appropriate colours.
It's not available from the suppliers I've used for electrical bits in the past (Light Up UK, Discount Electrical, TLC).
Any suggestions?
Thanks,
Tony S
Is the sleeving for identification purposes?
Yes, that's correct thanks.
I once purchased some earth sleeving from Edmundsons, that would easily over sleeve 6mm insulated cores. It was a couple of years ago though.
If it is for ID purposes, I would settle for the electricians tape to ID at terminals.
SWA also do heat shrink mixed packs of brown black grey blue and earth aprox 3 lengths of each about 300mm long , in various sizes up to about 20mm pre shrink diameter , 2:1 ratio, round here most wholesalers stock it
I don't think that anyone has yet asked why you feel that you want/need to over-sleeve the conductors.
It's for identification, as PrenticeBoyofDerry guessed earlier on. The cable as supplied is Brown, Black, Grey. For consistency I'd rather all three were marked in the same way, although Brown is already correct.
Can't help with short lengths.
http://www.swaonline.co.uk/heatshrink-insulation-sleeving/pvc-sleeving/pvc-sleeving
You could start a short length supply.
Trade only I think?
Generally I think that people selling something view everybody's money as equally valuable.
If you think they're a possibility I'll drop them a line, see if they'll deal on a cash basis. I suppose what I really meant was they seem to want to deal only with existing account holders.
Ah, I see. I wasn't thinking of 3-core (I presume probably SWA) but, rather, of red/black T+E.
If it were me, and if I didn't have an appropriate size of sleeving to hand, I would probably use heatshrink. It's obviously widely available in short lengths of a wide range of sizes and, despite what you said, is readily available in G/Y as well as brown and blue (and countless other colours) - as a quick search of eBay will indicate - for example, click here.
It might if you soften it in hot water and lubricate the cable.
A bit of a faff, and not practical if you needed to do it on a regular basis, but as a one-off, particularly if you've already got some 6mm sleeving, it's definitely worth a try.
