i have (had) a borrowed neutral, and some crazy wiring in my lighting circuit, most of which i have put right.
I have two two way switched top and bottom of the stairs, with the live feed going to the bottom switch, and the 2 ways running between them. however which is the most usual:
1. the live feed then goes back down to the floor, and then the live and neutral go up together to the landing light
-- or --
2. the live feed goes from upstairs switch to the landing light, then a separate cable goes from landing to attic. if so do i just run standard 1.5mm and ignore the live?
thanks.
-- or --
thanks.
