My current CH setup is a pressured sealed-system with a hot water tank and Worcester boiler. It has a Honeywell ST9400C programmer and a wireless Honeywell thermostat. Unfortunately the programmer is starting to fail (it keeps powercycling) so I'm looking to install the new Hive instead.
This is how the setup looks:
Programmer:
Wireless receiver:
Wiring box:
I believe I have an S Plan wiring setup (because of the two separate valves), so the wiring diagram looks a bit like this:
Question is, do I just swap out the programmer with Hive's dual-channel receiver? Do I need to do anything with the wireless thermostat receiver?
I can see that the thermostat connects to pins 4 and 5, with pin 5 controlling the heating valve, so given that I no longer need the thermostat receiver, do I need to wire pin 5 to the new Hive somehow?
Do I need to be concerned that there's no wires for CH and HW Off on the programmer?
Thanks in advance!!!!!
Paul.
P.S. I'm open to better than Hive suggestions?
Programmer:
Wireless receiver:
Wiring box:
Paul.
